Screen is blank after trying to turn on
My Note 20 Ultra was working fine. I turned off the phone while it wasn't being used, and when I turned it back on, the Samsung Note 20 startup logo showed for a few seconds and went away. After that, the screen was black, and nothing I do will make it work. I tried force restarting the phone, but I can't see any prompts on the screen.
Nathan Smith does it vibrate when you turn it on?
由 oldturkey03 完成的
Yes, there is a short vibration when I tried to force reboot it.
由 Nathan Smith 完成的
I take it it's charged? Stupid question I know but it will vibrate even with a dead battery. Leave it on charge for half hour. It may benefit from a battery disconnect reconnect if nothing else works. Could be a software glitch locking it up.
由 [deleted] 完成的
Yes, it had 85% charge when it was turned off, and I tried charging it overnight with a known good charger. I might leave it until the battery runs down and it shuts off.
由 Nathan Smith 完成的
You could always open the phone up, disconnect the battery for a minute then reconnecting it and see if it starts normally. You'll need some adhesive to seal it back up.
由 [deleted] 完成的
