跳转到主内容
The Chevrolet Silverado is a line of trucks under the Chevrolet brand and manufactured by General Motors. Mechanically, the GMC Sierra and Chevrolet Silverado are identical.
28 个问题 查看全部
Passenger side window will go down but not up
I have a 2008 Chevy Silverado 1500 that the passenger side window will go down but not up. It is the same with the switch on the drivers side door and the switch in the passenger side door. I have replaced the regulator with the motor and still have the same issues. I looked at the wires from drivers side door into the main body and none of them looked broke. Any help would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Don't know the vehicle but looking at the schematic for the right side power windows from the repair manual, (see image below) the regulator receives power from the logic board inside the passenger door switch to drive it either up or down.
I don't know which terminal on the logic board is used for up or down, X1 or X3, but since there are only the two wires going from the board to the regulator it would be easy to know as you say that it goes down but not up.
If you disconnect the two wires at the regulator and then operate the down switch you should get a voltage on one wire only and there is an earth on the other wire.
If you then operate the up switch there should be a voltage on the other wire but probably not. Most likely there will be an earth on the wire because the electronic switch in the logic board hasn't operated to switch over and provide the voltage for the regulator.
It could be the logic board in the passenger door switch that is the problem since the window doesn't work from either the driver or passenger window switch. There's no schematic for the logic board but maybe something is obviously wrong when you look at it e.g. burnt out component etc.
(click on image)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jason Hellwege 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 29
过去 30 天: 99
总计 1,485
