跳转到主内容
Casio CFX-200 released in 1983 Chromed base metal. CFX-20 Black resin with same module (not shown) Module no. 197
How do I reinsert the Cfx-200 module?
The module for my Casio CFX-200 is not fully seated into the case so some of the buttons are not working. I see that the buttons on the sides slip and interfere with the leaf springs on the module, is there a trick to getting them out of the way?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Can you attach pictures?
完成的
@johnftexas it'll help if we can see what and where you are stuck with it. Post some images with your QUESTION. You need to edit it and follow this guide 在已经存在的问题里加入图片
完成的
How do you remove the module from the case? I need to access some sticky side buttons. Thanks in advance
完成的
添加一条评论
1个答案
已选择的解决方案
So I took it back apart to take some photos of it then I decided to try again. I used a sewing needle to reach between the module and the case to push each side button in this allowing the module to seat further in. Long story short… it’s working about as well as when I got it in 1987😀. Thanks for your rapid response and I will remember to include photos next time I have a question.
JohnFTexas.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
John Finnell 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 23
总计 444
