跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 个问题 查看全部
iMac Black Screen No Chime Led 1 Fans Rev
Hi There.
I have a problem a back screen issue.
The fans turns on with the hdd and DVD drive.
I checked the onboard diagnostics and LED 2, 3 and 4 are off.
I have replaced the PSU but but still a black screen.
I have replaced the cmos battery but still black screen.
I have baked the gpu but still black screen.
Ask for any info about Imac.
Edit.
I forgot to mention I plugged in a different keyboard when it was working and when 15 min past it crashed and I could turn it on but it would crash less then 10 min in it would crash. The next day it would not turn on I have the issue now.
Update (01/08/2023)
@danj
This is the gpu
Update (01/08/2023)
The specs
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Sounds to me Like A Scary failed logic Board Or CPU!
Take it The board out and look for any corrosion,
And Check The CPU
Guide: iMac Intel 21.5" EMC 2428 Logic Board Replacement iMac Intel 21.5" EMC 2428 CPU Replacement
iMac Intel 21.5" EMC 2428 CPU图片
指南
难度:
困难
3 - 5 hours
iMac Intel 21.5" EMC 2428 Logic Board图片
指南
难度:
困难
1 - 4 hours
这个答案有帮助吗?
得分 4
61条评论:
完成的
Hmm... I'd say try reseating the CPU.
完成的
@beanman56
It didn't work I reseated the CPU. Still doesn't work.
完成的
@tomytom - Okay sounds like a faulty logic board then...
@oldturkey03 - Any thoughts?
完成的
@beanman56 - Often I find the GPU power rail is shorted to ground. Inferring a short with in the GPU board likely a burnt cap.
完成的
显示更多的56条评论
添加一条评论
添加你的答案
tomytom 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 488
