跳转到主内容
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
430 个问题 查看全部
Can I replace 6.3v and 2700 uf capacitor with 16v and 2200uf capacitor
I have Xbox 360 whose 3 capacitors have been exploded and i cannot find exact one so i wanted to know can i replace 6.3v 2700uf capacitor with 16v 2200uf capacitor. I will be waiting for your answer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @mateen_waris
Not really.
The value of 2700µF must have been chosen for a specific reason, so changing it to a lesser value might have an undesired effect.
The best way to achieve the value is to connect two capacitors in parallel connection so that their total capacitance is equal to the desired value.
To get this using standard value capacitors, the closest you can get is 2670µF by having a 2200µF + 470µF in parallel connection. For all intents this should be close enough.
Make sure that they both have the same working voltage rating. If you can't get 6.3V for both then make sure that both have either a 10V or 16V rating.
Here's a link that describes how to calculate the total capacitance value when capacitors are connected in series and parallel connection.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Mateenwaris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 360
