跳转到主内容
蘋果2020年的主流型號iPhone,其發布於10月23日,搭載6.1吋OLED螢幕及12MP雙鏡頭模組。其有著5種顏色,為iPhone11的後繼產品。
165 个问题 查看全部
iPhone 12/12 Pro Audio Control Cable and Wireless Charging Antenna
I need some advice on how difficult it is to replace the
"iPhone 12/12 Pro Audio Control Cable and Wireless Charging Antenna"
As long as I don't have to do anything with the back glass I think I am ok but since the part is $70 I was hoping for a repair guide but I cannot find one.
Any advice is appreciated.
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I should have added the reason for needing this replacement is that my volume button up does not work.
Thank you
完成的
添加一条评论
2个答案
最有帮助的答案
Thanks for the referral, @flannelist, but they've completely changed the volume button arrangement on the 12. On the X, the flex cable crossed over the back of the phone, stopping at the charging coil, then went to the motherboard on the opposite side.
On the 12, however, they switched the logic board to the left side of the phone. The cable now goes to the power button as well, so all four buttons are now on a single flex cable connected to the charging coil.
Replacing it will require removing the battery and the motherboard, just like on the X. I'd do a guide on it, but I don't happen to own an iPhone 12. However, others have done a video guide; here's one that looks reasonable on YouTube.
IPhone 12 volume side button flex replacement
If you prefer written, step by step directions, you can use the iFixit guides for the Battery, Front-Facing Cameras and Rear-Facing Cameras to get through the first part of that video, then follow along the video for the rest.
Many of the replacement flex cables I've seen do not come with the charging coil; I would strongly suggest getting one that is already soldered to the charging coil. For example, here's one on Amazon that would work.
AmazonSmile: YESUN NFC Chip Wireless Charging Charger Panel Coil Sticker with Power Volume Button Flex Cable Replacement for iPhone 12 & 12 Pro : Cell Phones & Accessories
Hope this helps, @paulc. Holler if you need any help along the way and let us know how it goes.
这个答案有帮助吗?
得分 2
1条评论:
Yup. They very much have. The 12 also contains that fun trap of a 5G antenna that's soldered to the bottom of the logic board and is very easy to tear if you don't know it's there.
My answer was written in haste so I wouldn't forget to post it :) Methodology is the same, but not everyone is me that rips apart iPhones without a second thought.
完成的
添加一条评论
I would follow the iPhone 12 battery replacement guide and then use the iPhone X guide as a reference for the actual wireless charging antenna .
iPhone 12 电池图片
指南
iPhone 12 电池更换
难度:
中等
1 - 2 hours
iPhone X Charging Pad / Volume Button Assembly图片
指南
iPhone X Charging Pad / Volume Button Assembly Replacement
难度:
困难
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
paulc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 204
