跳转到主内容
加入维修社区 - 创建账户
2006年11月, Wii 在北美市场发布。这是任天堂第一款支持直接连接互联网的电视游戏主机。该主机支持在线游戏,以及通过 Wii Shop Channel 分发数字版游戏和媒体内容。
Wii won't read disks and makes wired clicking sounds.
My Wii will take the disc but once it goes in a whiring sound starts then it clicks about 20 times before crashing discs will eject i figured its a disc drive problem but which is it?i have included a video if you need more info:
https://www.youtube.com/watch?v=5OUMRm-U...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi
That sounds like the disk drive had failed
You could try and repair it by taking it apart and checking what it looks like on the inside and give it a good clean, it will most likely need replaced but it’s worth a try
Here’s the guide you will need
如何帮任天堂Wii主机更换光驱
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
2条评论:
Hello so i opened it up did some testing and cleaning and it turns out along with this issue i have a laser issue so and at this point it would be to expensive for me right now but the other than the disc drive the wii still works so i might come back to it on a later day
完成的
@lostresort_
Hi
That sounds like a plan
完成的
添加一条评论
添加你的答案
LostResort_ 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 31
总计 718
