跳转到主内容
加入维修社区 - 创建账户
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南,拆解信息和支持文档。本产品型号为 CFI-ZCT1W,主板型号为BDM-010。DualSense 系列手柄取代随 PS4 同期发布的 DualShock 系列手柄。
The ps button on my ps5 controller not responding?
I've opened up my controller and checked to see what it could be. But i do not see any reason why the button is not responding when i put it back together. I have cleaned the the casing the pad and everything the ps button touches but no response
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
19条评论
Same, And I doubt someone has the answers, If you’ve fixed it by now I would appreciate if you’d reply
完成的
I haven't fixed it yet, i still cannot identify the problem. I thought this chat room would help as it is very informative with issues on gaming equipment. Hopefully someone can give me some insight
完成的
When you plug it in, does the light bar slowly light up orange then quickly flash off one time? If so then it’s the same issue as mine. Can’t seem to find any insight or answers for this. I even tried swapping battery from a known working dualsense; didn’t work.
I bought the Dualsense controller for use with my iPhone, until I can afford a ps5 console. There is even less information and answers out there for people with an issue but no console… please update if you have found anything.
完成的
@sirswolls Having the same problem as you do after a shell swap, any answers yet or fixes?
完成的
@gamechan you might need to open it back up.
have you checked that all connectors are fully on?
are any cables torn?
did you damage any components?
could any of the componets have been affected by ESD (electric static discharge)? (you can check by seeing if your workspace is has a sticker or anything like that that claims to be esd safe, or if the table you worked on was completely wood, lol)
完成的
显示更多的14条评论
添加一条评论
1个答案
最有帮助的答案
Here’s some pictures, unfortunately I can’t add any videos longer then 30 seconds so this is the best I can show for now. But I managed to fix the orange light problem by replacing the battery of the controller.
这个答案有帮助吗?
得分 2
4条评论:
i can't see them, maybe this is a me problem tho, lol
nvm i can't see them on anything
完成的
@timtomissus I'll try something else hold on
完成的
@gamechan, here's how to add pictures to your answer.
在已经存在的问题里加入图片
完成的
@dadibrokeit thank you <3
完成的
添加一条评论
添加你的答案
Munir Umar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 57
总计 2,193
