跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1526 个问题 查看全部
apple logo appears for 1 second and then switches to just backlight
before all of this happened, my iphone was freezing every 5 minutes or so, and would only unfreeze if i plugged it in for a few seconds and then it would go to the lock screen. Then, i was stupid and updated to 12.5.6, and it was stuck with the progress bar at 99%. Then, it rebooted, but when it reached 75% it would reboot, and every reboot it would reboot faster, until we reached this stage. I dont have the crash logs anymore, but the error code was WDT and it was something about no battery data on the end (?).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Based on your initial panic, my inkling is that it could need a new battery.
But the Apple logo shows and then goes super dim also points to a possible issue with the Ambient Light sensor.
I would give a battery replacement, and a replacement of the front facing camera assembly a go to start and see if that sorts your issue. The iPhone 6 plus is one of the easiest to repair iPhones. No adhesive between you and the guts of the phone which is a win on the repairability front anyways.
iPhone 6 Plus 电池图片
指南
iPhone 6 plus 电池更换
难度:
中等
15 - 45 minutes
iPhone 6 Plus 前置摄像头和传感器组件图片
指南
iPhone 6 Plus前置摄像头和传感器组件更换
难度:
中等
1 - 2 hours
这个答案有帮助吗?
得分 2
1条评论:
thanks for the suggestion. if i cant find another way, i dont think ill do that because ill get a new iphone anyway, i just wanted to see if i got this one working.
完成的
添加一条评论
Another user suggested battery and display replacement, but I have a bunch you just need a good restore. Perhaps it'd be something you could try before replacing parts?
Connect your phone to your computer. To place your device in DFU mode, begin by holding the power and home button until the screen goes blank. Release the power button and continue holding the home button.
Your computer (itunes more specifically) should recognize a device in recovery mode, allow it to restore your phone as normal.
这个答案有帮助吗?
得分 0
4条评论:
the problem is, altough i can get it to have the backlight when connected to the wall, that doesnt happen if its connected to the pc. it just stays turned off.
完成的
@coce That sounds like it may be a power delivery issue. Backlight consumes a lot of power. You don’t need backlight though to process a restore. See if you can get it into recovery mode and either update or restore.
完成的
@flannelist the problem is it literally wont boot if plugged in to a PC, and the PC wont recognize it. I might try to find a way to have it plugged in to AC and my PC at the same time.
完成的
@coce If it boots on a wall adapter and not via a usb connection to a computer I am inclined to thing that’s still a battery issue. Or a charge port one. The lightning connector on iPhones is limited to USB 2.0 specs when connected to a computer (If I recall correctly). That means 500 mA of current for charging. That’s half what the charger brick that came in the box with the phone can output and a quarter of what Apple’s standard charger outputs now in 5V mode.
That might just not be enough to get enough power into the battery to boot it. I still think new battery is your best bet.
完成的
添加一条评论
添加你的答案
Light Yagami 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 61
