跳转到主内容
Low Water pressure from my in door water dispenser
I recently changed my water filter in my whirlpool french door refrigerator, as I have done several times before. This time when I inserted the new filter, the water just trickles from the dispenser. I removed the filter and water pressure is fine. I thought it could be a bad filter so I tried a different filter. Same result. It has never done this before until this time. Tried purging the air but it doesn't spit & sputter, just trickles. Any advice is appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
No dripping, no spiiting just very slow flow. I have watched the video previously and followed this steps but it did not fix the slow flow issue. If the filter is removed the system goes into "bypass mode" and the flow is strong. What am I missing??
完成的
@Jim Green
What is the model number of the refrigerator?
完成的
添加一条评论
1个答案
最有帮助的答案
Flushing the system is needed every time the filter is changed or once the refrigerator is installed to the water supply line for the first time.  The air in the water system may cause dripping at the dispenser that is considered a leak or for the water to dispense slowly.
Here is a video and instruction on how to do this:
https://producthelp.whirlpool.com/Refrig...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jim Green 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 23
过去 30 天: 111
总计 676
