@dattaram that is usually caused by bad power transistors on either the mainboard or the power board. We would need to know the exact model number for you TV and what you have checked. Sometimes even a simple reset where you disconnect everything from your TV, then unplug the TV and hold the power button depressed for about a minute , might work. Do you connect your TV through a network? If so check that as well.
由 oldturkey03 完成的
Could you take the back off your TV and upload pictures of the circuit boards? 在已经存在的问题里加入图片
由 Andrew S 完成的
