跳转到主内容
加入维修社区 - 创建账户
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南,拆解信息和支持文档。本产品型号为 CFI-ZCT1W,主板型号为BDM-010。DualSense 系列手柄取代随 PS4 同期发布的 DualShock 系列手柄。
What would cause a bumper button to not work
I have a PS5 Dualsense remote with a suddenly non-functioning R1 button.
  • No physical damage to the remote from dropping/excessive force has been exerted
  • No water damage
  • The black plastic part of the button is in the correct position. Removing to access the silicone part of the bumper button and pressing with a pry tool/screw driver does not work
  • R2, L1 and L2, as well as all other functionality is perfect
  • The remote is a v1 remote
I've tried disassembling the remote and investigating, nothing out of the ordinary to report and I'm at wits end. Any guidance would be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Ended up being a microtear in the ribbon cable through some of the middle connections, which obviously affects the R1 button in particular.
Easy enough to replace, but I can imagine that with the design of the right ribbon cable being more exposed it could potentially lead to more issues over the left one
这个答案有帮助吗?
得分 0
1条评论:
Had to buy a new L1 bumber it goes in normally & even works but won’t stay in the holder whatsoever. Falls right out when I turn controller upside down or tip it over confused tried everything what could it be ?
完成的
添加一条评论
How do you fix the micro tear
这个答案有帮助吗?
得分 0
1条评论:
Replacement ribbon cables can be found on Amazon. Watch for the generation controller you have though as apparently there are several and some use slightly different cables.
完成的
添加一条评论
My L1 has the issue even after replacing ribbon cable with new one iam still facing the same issue don't know of it's hardware to software issue
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jarod Kurland 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 71
总计 6,492
