Enable advance option in bios setting
Want to enable the advance option in bios setting for virtualization activation
Let's start by confirming virtualisation is supported by your CPU (it's a given you'll also need at least 4GB of RAM). To do this, press Ctrl+Alt+Del keys and select Task Manager from the menu, click the Performance tab and then select CPU. "Virtualization" entry should be enabled. You can also:
* download AMD Virtualization Technology and Microsoft Hyper-V System Compatibility Check Utility. After unzipping the file, run amdvhyperv.exe and see the result.
* use other system info software of your choice, like Speccy or SecurAble(portable) etc.
Next, let's see if it is possible to enable it from your BIOS, here's some fixes some users on Acer forums reported to work:
Note that a machine running Win 10 Pro/Edu/Enterprise is required in order to use Hyper-v(MS's virtualization platform). Now the problem is, on modern Windows OS, Hyper-V tends to disable VT-x / AMD-V by default to avoid conflicts with programs like VirtualBox & VMware, also some Windows features could be preventing you from normally running your virtualization software, as they give priority to hyper-v over AMD-v; VirtualBox 6.1.x for example now requires VT-x/AMD-v to be available, for more insight check out this topic. So If you're experiencing problems you should disable Hyper-v (just run "appwiz.cpl" to access the Windows features menu and un-check it) in case you wanna run VB or similar; you can also try out Windows Hypervisor Platform, which supposedly will allow you to run VirtualBox even with Hyper-v still on.
Finally, if the problem persists you can contact Acer Support centre and expose the issue to see if they can help you.
这个答案有帮助吗?
I will try the mentioned method, thank you for the response
Ur welcome, I hope this helps
过去 24 小时: 3
过去 7 天: 43
过去 30 天: 167
总计 19,519
3条评论
What operating system is your computer running?
由 Andrew S 完成的
Windows 10 home , laptop is Acer aspire E5 553G T9VU, processor is AMD A10 7thGen
由 mayur shinde 完成的
I don't think there is a way to enable virtualization in the BIOS. I heard people are modifying the BIOS values to do this
由 Kuromi 完成的
