跳转到主内容
20", 23", 和 30" LCD 显示器 发售于2004 于 2010年停产。
95 个问题 查看全部
Cinema display 30-inch 2007. I can't get the resolution up to 1280x800
I have an Apple cinema display 30-inch 2007. I can't get the resolution up to 1280x800. i changed all connections dvi, hdmi. I work with a 2013 Mac Pro 6.1 and a 2010 Mac Pro.
I have two 30-inch 2007 displays and one works fine at 2560x1600 resolution. The other connecting to the same computer only gives 1280x800 resolution.
Is there any new firmware someone could help me?.
What do you think is the fault?
Thank you very much. Regards Harry Macias
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
You do need to make sure the DVI cable offers 1920 x 1200 or 2048 x 1280 for single-link resolution or 2560 x 1600 resolution with dual-link format
Types of DVI cables:
There are three types of DVI cables available at this point in time.
  • DVI-A: This cable transfers analog signals only. This connector is used to connect a DVI card to a CRT monitor (an older type of monitor). The signal from this cable is converted from digital to analog but still produces higher image quality than VGA.
  • DVI-D: This cable transfers digital signals only. This is the most popular type of connector for hooking up DVI cards to LCD monitors. This cable comes in single-link and dual-link formats. The dual-link format offers more power and a faster data transfer rate than the single-link format.
  • DVI-I: This cable transfers both digital and analog signals and is compatible with digital and analog equipment, acting as a DVI-D or DVI-A cable. With that said, it cannot convert pure DVI-D output to analog.
这个答案有帮助吗?
得分 1
11条评论:
Goodnight. Thanks for your reply. I use to test the same cable that works at maximum resolution in a 30" cinema. With the computer that is currently working at maximum resolution. When I connect it to the Cimema 30" that does not give maximum resolution, the screen lights up with stripes of vertical and horizontal colors without letting see the image that is behind. I have tried all types of connectors and found out what type of DVI to use.
完成的
@harrymacias - Then the circuitry within the display is having problems.
完成的
When I connect it to the macpro 6.1 the resolution that it supports or the maximum that it indicates in the screen configuration is 1280x800. The cable I use is Thunderbolt and DVI 4K X 2K connector. That according to the seller gives the resolution 2560x1600.
完成的
Ok.Would it be likely that it does not work at maximum resolution and if at half? I think that if you remove a cinema and change it for another it should still work fine. Which plate would be the one that has to be changed?@danj
完成的
@harrymacias - I'm confused, Same system MacPro6,1 (TrashCan) display A works and display B using the same cable. If that's true then it's the display.
If you are having issues with your MacPro (2010 Cheese Grater) MacPro5,1 then you have an issue with the GPU board. If it works correctly on the TrashCan.
完成的
显示更多的6条评论
添加一条评论
Hey, have you managed to solve this?
I have the same problem on my monitor and I am (apparently) the right adapter for my computer, a Dual Link to USB C (the club 3D one). I also got similar stripes as you. This adapter should have enough bandwidth so I am almost sure it must be something with the monitor.
Thanks
这个答案有帮助吗?
得分 0
2条评论:
@efernandezabril do you have a link to your adapter?
完成的
Yep, this one!
https://www.amazon.com/dp/B08B7FSVTL?ref...
I wrote a lenghtier post about whats happening to me here:
30’ Cinema Display > DVI to USB-C > M1: Erratic behaviour, need help!!
I'd appreciate any help I can get!
完成的
添加一条评论
添加你的答案
Harry Macias 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 25
过去 30 天: 127
总计 717
