Why I turn to my phone to landscape mode my display touch is to week
When I turn to my phone landscape my display touch response is too weak
One of the best ideas I've seen for diagnosing touch screen problems is to bring up a drawing app, preferably one that will work full screen, and attempt to draw over the entire screen. The areas that aren't responding to touch won't be colored in so you'll get a visual idea of exactly what's not working.
In your case I would try it in both portrait and landscape mode and see if there's an actual difference.
Once you've done that, add pictures of the results to your question and we'll see what you've got there.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 222
5条评论
@achukutty what exactly do you mean by "to weak"? Is it actually working or only in certain areas?
由 oldturkey03 完成的
Display not working on certain areas
But I can play games with third party apps
由 Achu kutty007 完成的
@achukutty is it always the same area that gives you trouble? Does that same area give you trouble in portrait mode? You have no problems with this in third party apps?
由 oldturkey03 完成的
@oldturkey03 no only landscape mode
Yes no issues on third-party applications
由 Achu kutty007 完成的
@achukutty if you have no issues when using third party apps it will not be hardware related. Check your settings and you may have to reinstall/update your firmware. I suggest you check sites like this one or on here
由 oldturkey03 完成的
