跳转到主内容
苹果第四代智能手表,含可选的蜂窝连接支持,2018年9月21日发布。
124 个问题 查看全部
Which lcd adhesive to use
I will be replacing the battery in my series 4 and wanted to confirm the best adhesive to use when sealing the lcd back into the watch keeping full waterproofing still. I've seen people use b7000 or you can buy the precut tesa tape but I was told cold press glue is the best thing to use?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Use the recommended adhesive strip:
Apple Watch (44 mm Series 4/5) Adhesive Strip
Apple Watch (44 mm Series 4/5) Adhesive Strip图片
产品
$6.99
这个答案有帮助吗?
得分 3
添加一条评论
B7000 should work just fine, but make sure to wipe off any seepage before letting it dry.
这个答案有帮助吗?
得分 2
2条评论:
The watch will still be fully waterproof after using b7000?
完成的
@ntec No, you shouldn't trust anything underwater after they have been repaired. If you want a bit more peace of mind, use the product in the answer from @mayer, but don't put it in water.
完成的
添加一条评论
添加你的答案
John Nguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 258
