跳转到主内容
The Early 2009 Mac Pro—also known as the Mac Pro 4,1—introduced Intel's Nehalem architecture to Apple's line of professional desktop computers in March 2009. The Mac Pro 5,1 used the same interior design but received further CPU updates in 2010 and 2012.
201 个问题 查看全部
Will be this RAM compatible?
Hi guys,
will this RAM work in Mac Pro 5.1 ? Currently CPU support only 1066MHz but will be updated to X5690 and this CPU support 1333MHz.
https://www.amazon.com/Samsung-M393B2G70...
or
https://www.memory4less.com/hynix-16gb-d...
Anyone have it ?
Thanks a lot.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Give this a view Upgrading my Mac Pro to the MAX CPU and RAM
这个答案有帮助吗?
得分 1
10条评论:
Thanks for the video. But my main concern is that these RAM’s are 1600MHz and MP with top CPU can do only 1333MHz.
完成的
@roboscrap - Watch the vid again as he explains which can support the higher speed RAM.
完成的
@danj I am wondering if anyone have experiences with exactly these types of RAM’s as they are 1600MHz and I don’t know if they can run on 1333MHz. And he talking about 1066 and 1333MHz.
完成的
@roboscrap - You are limited by two factors: The given chipset the logic board offers and what the CPU can support. The maximum speed RAM is either 1066 or 1333MHz depending on the logic board. While it might be possible to install 1333MHz it won't run any faster than what the logic board supports.
完成的
@danj so if I use 1600 even 1866MHz it will RUN, but only on 1066 or 1333MHz depend on CPU (logic board can do 1333MHz)? Because I know that some RAM’s can’t “slow down” - had this issue with PC, but I am new to Mac Pro world. That why I am asking.
完成的
显示更多的5条评论
添加一条评论
So I ordered 8x Samsung 16GB DDR3 ECC 1600MHz (details below!) and it's working for now :) running at 1066MHz. So this memory stick's are compatible with MP 5.1 (if you have dual CPU you can go up to 128GB).
Will let you know if I will have any issues in future :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 158
