跳转到主内容
加入维修社区 - 创建账户
Released September 2016. Identified by Model No. SM-G610
Testing with another device's screen
I got a J7 prime with a completely dead, broken and miserable screen.
Took it apart (not wearing gloves, oops) and seems like the rest of the components is fine.
So I got a spare screen from a J5 prime (which has the same connector), then tried to turn it on from USB power... No success.
Is it correct to deduce that the phone is dead? Or is it simply not compatible with another model's screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi @sharkaroid
Here's the No Power troubleshooting flowchart from the service manual that may help.
Looking at the chart, if there is no power on sound or vibration sound then there's a problem with the systemboard.
这个答案有帮助吗?
得分 2
1条评论:
@sharkaroid it is possible that your incorrect display is actually preventing your phone to come on. Remove the wrong LCD altogether and give it a try or even leave your old one connected. Like it was previously stated, if you do not get any vibration etc. on startup, the issue is not your display.
完成的
添加一条评论
You’ll need a matching screen. Not all screens are compatible even if the connectors fit.
这个答案有帮助吗?
得分 1
2条评论:
but even with an incompatible screen, would the phone turn on and vibrate if it's working?
完成的
@sharkaroid Even without a screen the phone would still turn on.
完成的
添加一条评论
添加你的答案
Ana Clara Forcelli 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 335
