跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
170 个问题 查看全部
My pc will not connect to my monitor
The pc will not connect to my monitor yes i have tried a new hdmi cable and a different display but there is still no signal i removed a ram stick and cleaned it out i took out my graphics card i have removed my ssd to see if it would boot the bios with my hard drive still didnt work i have removed my battery for the mother and put it back and still no display im genuinely lost i hope its not my graphics card as i have no way to test it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi ,
If the motherboard doesn't display any codes then try listening for any beep error codes that may be heard during POST (Power On Self Test)
Connect a system speaker (example only to show what it looks like) to the appropriate F_Panel header pins on the motherboard.
See Item #12 (F_PANEL (Front Panel Header) on p.21 and p.15 of the motherboard manual for the location.
这个答案有帮助吗?
得分 2
添加一条评论
Good morning,
Firstly, can i get the specs of your PC? This may help explain it as without these, i am pretty lost as to what the real issue is. Also can you answer these questions for me?
  • Do the fans spin?
  • Does the motherboard display post codes on little leds? If so, what is the sequence of postcodes it goes through?
  • Does it reboot after that sequence of post codes?
  • Have you tried plugging into the integrated graphics of your chip (If applicable) or, have you tried phoning a friend to see if they have a spare graphics card you can check with
这个答案有帮助吗?
得分 1
2条评论:
Everything spins the motherbard does not display codes neither does it reboot im pretty sure my motherboard does not have integrated graphics sadly my friends are busy and i live far
But other than that my build is
Nvidia 3070
Ryzen 7 5800x
Aourus x570 elite
Team group ssd
Silicon power ram of 16 gb
完成的
CPU is the one w/o integrated graphics. I think if your motherboard doesn't display codes it's the motherboard. But this is a weird issue
Maybe try a different CPU if u have one around
完成的
添加一条评论
添加你的答案
Dragon Cortez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 44
