跳转到主内容
The sixth-generation Elantra was introduced in 2015 in South Korea and released for sale in the North American market in 2016 for the 2017 model year. The 2015-2020 Elantra has been sold in SE, Limited Edition, Ultimate Edition, Sport, and Value Edition trim levels.
13 个问题 查看全部
What does is mean when my car gears don't work
My 2015 Hyundai Electra turns on and everything but now when I put it in reverse it don't move or on drive.. I press the gas and nothing.. people tell me different things of what could be the problem but I want to know what could it be and if it's fixable
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thank you so much for answering.. yes that means so much sense and clear.. yes I'll let you guys know the results
完成的
添加一条评论
1个答案
已选择的解决方案
Hi Rachel,
I'm going to start with a couple of assumptions, so let me know if I'm wrong on anything because that could drastically change what my answers would be.
First of all, I'm going with the belief that you meant "Elantra" rather than "Electra" in your question. Secondly, my answer is based on the idea that you're talking about an automatic transmission rather than a manual.
Okay, with that out of the way, there are a lot of reasons why an automatic transmission won't go anywhere. The simplest, and possibly the only one most of us home mechanics can take care of ourselves, is if it's low on fluid. It appears your car uses what's called a "Sealed Fluid System", meaning there's no dipstick to check the fluid. So topping up the fluid gets a lot more complicated than just getting out a funnel and filling it till the dipstick reads full. Here's a page from a the Hyundai forums describing the procedure for your car.
Automatic Transmission Level in 2015 Hyundai Elantra
Being a sealed system, there should not be any loss of fluid, so if this is the case, there's a leak somewhere that will need to be fixed, and depending on how badly it's leaking you may or may not need to fix that leak right away. Look under the car where it's been parked for any red (or possibly brown if it's old), oily fluid on the ground.
Other than that, there are many other things that can go wrong with an automatic transmission, but unfortunately very few of them can be fixed by us home mechanics. Here's a web page off a car site discussing possible reasons for transmission failures in your car.
Most Common 2015 Hyundai Elantra gt Transmission Problems - MyCarSpecs United States / USA
Virtually all of those problems listed would need to be fixed by an experienced transmission mechanic, which won't be cheap. I'd suggest that your next step should probably be to take the car to a transmission shop (obviously you'll have to have it towed) and have a diagnosis done on it. You'll almost certainly have to pay for it, but at least at that point you'll know what you're dealing with.
If it was my car and the cost to repair the transmission was prohibitive, my inclination would be to buy a used transmission from a wrecking yard and replace it myself. I'm fortunate in having the experience and tools to do that job but I understand that it is a major repair and not something most people can tackle. Probably the cheapest solution would be to find a mechanic willing to replace the transmission with a used one, but even that is going to run up a significant bill.
These are just my own personal thoughts on this and I'm certainly no expert on Hyundai transmissions. Hopefully some of our other members will have ideas of their own that could help.
Best of luck with your car; let us know how it goes.
这个答案有帮助吗?
得分 1
1条评论:
Even if you don't have the experience of doing it, the way I see it is doing a transmission in a "commodity" car yourself eventually means if you see that classic you want but good mechanics who can aren't common/will not work on it means it can be yours if you can do your own repairs.
To be professionally candid about Hyundai/Kia... I'm not a fan. They have problems with engine fires, oil consumption, interference engines which use TIMING BELTS (not a chain, like the rest of the world) and are known to be troublesome once you border 100k miles. Newer ones are better, but the early ones and the horror stories put me off. I would rather get a Camry with 250k trouble free miles over a Hyundai. A good Japanese car will run half a million miles without a sweat, with some of them running a million+.
To provide some context, I never learned by being told you may need this "just in case", or to pass a test. If you tell me that, I no longer care. But if you tell me knowing how to do the repair means I can have what others pay more for because I know how to test it and can source parts (either piecemeal or a donor) I'll find out how. I have told people at work how I still run a 2014 rMBP this late in without a fuss -- I self repair it and do my own maintenance like opening it to blow the dust out, or redoing the thermal paste. It even scares some of them off.
完成的
添加一条评论
添加你的答案
Rachel 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 33
总计 215
