跳转到主内容
Released August 2012, it is identified by its model number M4700.
Need a specific spot picture to see what's missing
I got a dell m4700 from a friend but it doesn't work. He told me "I upgrade the ram and tried to change the thermal paste but I didn't know how to do it so I didn't and now it freezes on the dell logo" I replace the thermal paste and it still doesn't work but I found board damage so I would like to see someone's laptop to compare.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Roberto4273 it will work a lot better if you post images of your board with your QUESTION. Let us see what is missing/damaged etc. Edit your QUESTION and use this guide to add images 在已经存在的问题里加入图片 You also want to make sure that you give us any identification about your motherboard (not just the Make and model of your laptop but the actual board) just in case there are schematics for it etc. and from what I see it should be a Compal LA-7931P board Dell Precision M4700 LA 7931P Schematics
Dell Precision M4700 Motherboard Replacement
Update (09/18/2022)
Looks like you lost at least PQ503 which is a SSM3K7002FU_SC70-3D Mosfet. I suggest remove the board check for further damage and replace the transistor. It looks ( a bit hard to see) like all the solder pads are still there.
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
Dell Precision M4700 Motherboard图片
指南
难度:
中等
30 - 45 minutes
这个答案有帮助吗?
得分 2
1条评论:
I added a better picture
完成的
添加一条评论
添加你的答案
Roberto4273 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 129
