跳转到主内容
加入维修社区 - 创建账户
第三代 11 英寸 iPad Pro(型号 A2377、A2459、A2301 和 A2460)的维修文档。于 2021 年 5 月发布。
top volume button isn't working
the top volume button is stuck. is there any way to fix that?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
You'd have to remove the screen and maybe, depending on location remove the motherboard too. Then remove the plate behind the buttons to remove and clean them and the opening for the buttons. Unless the area around the buttons has been damaged. If you haven't removed a ipad screen before go real easy as there's a risk you'll break it.
这个答案有帮助吗?
得分 1
1条评论:
Thank you. Definitely helpful but I’m not that tech savvy. Have a great day!
由完成的 分享
添加一条评论
Check your iPhone's volume settings (sound settings) to make sure that volume buttons aren't disabled. To do this: Open the Settings app. Tap Sounds & Haptics
Regards,
Will
这个答案有帮助吗?
得分 0
1条评论:
Thank you - will try that.
由完成的 分享
添加一条评论
my power button is not working well, it is mostly stuck. Can this be fixed?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pam 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 23
总计 584
