跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
LCD not working, LogicBoard Cable broken
I bought a broken iPod Touch 4th Gen.
Its Display is not working.
After opening the device I recognized that the upper front logic board cable with labeling as seen here:
iPod Touch 4th Generation Front Panel Replacement
is broken:
http://imageshack.us/photo/my-images/820...
1. What function does this cable have?
2. Any suggestions how to fix this problem WITHOUT buying a whole new logic board.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
the broken part is the WiFi Cable I'd be surprised if that is the cause of it not working. Someone has obviously opened it up before. Keep looking. THIS TEARDOWN may assist you in disassembly as may THESE GUIDES
What happens if you plug the iPod into a PC and start iTunes? Is it recognised?
HIH
Replace the Wi-Fi antenna and cable compatible with the A1367 model 4th Gen iPod touch.图片
产品
iPod touch (4th Gen) Wi-Fi Antenna
$12.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
bhaeussler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,070
