跳转到主内容
加入维修社区 - 创建账户
通用汽车 (GM) 旗下 Oldsmobile 品牌汽车的维修和支持指南。
Why wont my car still start?
I have a 1999 oldsmobile alero I just replaced the ecu box and ignition . The security light finally stopped blinking and the doors chime again and the trunk opens again but it still won't start. When trying to start it it does turn off like it did before switch parts now it seems like there is no gas or battery no juice but there is gas and battery good. Why won't it start still?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
There is gas in the gas line to the injectors. Is it suppose to be under pressure or weak when push on gas rail?
完成的
Yes, there should be pressure with fuel spraying out when ignition is turned on. Presuming the fuel pump is working with pressure on the fuel rail, this doesn't tell you if injectors are operating. After several starting attempts, spark plugs should be wet with fuel to indicate injectors are operating.
完成的
添加一条评论
1个答案
已选择的解决方案
Is this Passlock security? The bcm and ecm have a security password that requires 'marrying' each other thru a procedure. Dealers use their scantool to marry these components in 10 minutes. Diyers without GMs scantool must perform three 10 minute ignition on cycles to marry these components. The ignition switch contains an embedded resistor that's learned in this procedure before security allows normal starting. GM may disable injectors when a theft attempt or security parts are replaced without a relearn (marrying) procedure. Passlock security flashing indicates either a theft attempt or relearn not performed to turn it off. If off during starting then verify spark and removing a spark plug to smell it for gasoline. And check for blwon fuses.
这个答案有帮助吗?
得分 2
2条评论:
Thank you for your advice. I tried the 10 min 3 times and now the car is running. Thank you so very much.
完成的
I'm glad this worked for you. All I did was pass on free info. You did all the work.
完成的
添加一条评论
添加你的答案
Jennifer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 30
总计 424
