跳转到主内容
The HP Pavilion 15 cs0xxx is a 15-inch laptop that was released as part of the HP Pavilion computer line.
Why my laptop is working slow?
my lap work slow the boot take 1-2 min & after that it takes 40s to get prepare system
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Which OS do you have installed? It would help to know if this happened gradually or overnight (any recent hardware/software upgrade?), and whether the system's overall responsiveness degraded as well or it's just the boot times
完成的
添加一条评论
2个答案
I would try an m.2 ssd it is direcly attached to the motherboard and would be quiker the other idea is to rearange the boot order. This would be done by entering the bios by mashing the esc button until you see the boot options screen the enter the bios and then go to system configuration then navigating to the boot order press enter this will take you to another screen and put the ssd the os is on to the first option.
这个答案有帮助吗?
得分 0
添加一条评论
i can see your problem be the CPU if you look close your processor is Intel Core i7-8550U 1.8 GHz
and the U means "ultra-low-power," they're instead low-power designs made with efficiency in mind. They have lower clock speeds, lesser cores, and more importantly, a very low TDP.
all the other part of your pc is good but you can search for way or solution for your processor to be faster
good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
3049 HARSHUL PATEL 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 446
