跳转到主内容
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 个问题 查看全部
replace PATA optical drive with an SSD drive
last night I had a crazy idea!
would it be possible to replace optical drive (PATA)
with an SSD drive?
the only problem is the PATA connection instead of SATA, I don't know if there is an adapter or PATA SSDs
edit: I found this:
[ http://eshop.macsales.com/item/OWC/SSDMX...|OWC Mercury EXTREME Pro Legacy Edition 9.5mm for IDE/ATA desktop systems]
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Here's what you need to put in a SATA hard drive in your PATA optical bay slot: [关联产品丢失或禁用: IF107-078]
这个答案有帮助吗?
得分 5
4条评论:
from the notes on the link: This enclosure does not work with ATA drives or hard drives thicker than 9.5 mm.
plus: Compatibility >> MacBooks
完成的
Try this one: [关联产品丢失或禁用: IF107-079]
完成的
again on the notes: This enclosure does not work with ATA drives or drives taller than 9.5mm.
which I don't understand why! PATA drives have different sizes?
完成的
what you think? can I use this:
http://www.youtube.com/watch?v=BwRClahcU...
完成的
添加一条评论
ok finally I can answer to my own question!
this a Caddy for this type of iMac. It converts Sata (internal) to Pata (external) you can use any data connection 2,5" drive (ssd or hdd).
here is the site selling it:
http://www.newmodeus.com/shop/index.php?...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
joleisa 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 3,831
