跳转到主内容
The 2018 version of the Samsung Galaxy A7 smartphone released in October 2018.
52 个问题 查看全部
Dropped my phone screen is black but the notification are still coming
Hy. So my phone split of my hand and hit the floor it was about 50 cm after the screen was black i could hear the notification but the screen was black my phone has glass protector the screen is not DAMAGED pls help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi,
Just because the screen appears not to be damaged doesn't mean that it didn't suffer any internal damage that is not visible e.g broken connection in the display panel.
As a DIY repair all you can do is to temporarily replace the display assembly and check if it works or not. This is to find out if the problem is in the display or on the systemboard.
Here's the ifixit Samsung Galaxy A7 (2018) Display Assembly Replacement guide that will help.
Search online for Galaxy A7 (2018) display assembly to find suppliers that suit you best.
这个答案有帮助吗?
得分 2
添加一条评论
You could try to force restart the phone by holding the volume down and power button until it restarts. You should feel a vibration when it is turning back on.
But most likely the screen is damaged. The glass may not be cracked but the OLED underneath the glass probably is. So a screen replacement would most likely be the solution to your problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sᴘᴏʀᴛ ᴄᴇɴᴛᴇʀ 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 108
总计 903
