跳转到主内容
Samsung Galaxy A7 (2018) Display Assembly Replacement
你所需要的
视频概述
  1. Samsung Galaxy A7 (2018) Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,2 Samsung Galaxy A7 (2018) Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 2,2
    • It's better to use Display Assembly (Screen With Frame) to fix your broken device.
  2. Samsung Galaxy A7 (2018) Display Assembly Replacement, Battery Cover Removal: 步骤 2 中的图像 1,3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Battery Cover Removal: 步骤 2 中的图像 2,3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Battery Cover Removal: 步骤 2 中的图像 3,3
    • Use hot air to warm the device and soften the adhesive type.
    • Gently separate the back cover.
    • Use Suction Cup and a plastic opening tool (Paying cart).
  3. Samsung Galaxy A7 (2018) Display Assembly Replacement, Middle Frame Removal: 步骤 3 中的图像 1,3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Middle Frame Removal: 步骤 3 中的图像 2,3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Middle Frame Removal: 步骤 3 中的图像 3,3
    • You need a screwdriver Phillips to remove all 9 screws.
    • Again - using only Plastic tools remove the middle frame.
  4. Samsung Galaxy A7 (2018) Display Assembly Replacement, Test New Spare Part: 步骤 4 中的图像 1,3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Test New Spare Part: 步骤 4 中的图像 2,3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Test New Spare Part: 步骤 4 中的图像 3,3
    • Once you have access to the battery, disconnect it.
    • Test the new screen before installing it.
  5. Samsung Galaxy A7 (2018) Display Assembly Replacement, Sub board Cover Removal: 步骤 5 中的图像 1,2 Samsung Galaxy A7 (2018) Display Assembly Replacement, Sub board Cover Removal: 步骤 5 中的图像 2,2
    • Use Phillips Screwdriver and plastic tool and remove the Sub board cover.
  6. Samsung Galaxy A7 (2018) Display Assembly Replacement, Logic Board Removal: 步骤 6 中的图像 1,3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Logic Board Removal: 步骤 6 中的图像 2,3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Logic Board Removal: 步骤 6 中的图像 3,3
    • Remove the black Philips screw and gently take out the Mother board.
  7. Samsung Galaxy A7 (2018) Display Assembly Replacement, Sub Board Removal: 步骤 7 中的图像 1,3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Sub Board Removal: 步骤 7 中的图像 2,3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Sub Board Removal: 步骤 7 中的图像 3,3
    • Remove the Antenna Sub-PBA board.
    • It's easier to take out the sub board if you warm it a little.
  8. Samsung Galaxy A7 (2018) Display Assembly Replacement, Receiver, Vibrator, Loudspeaker, Battery Transfer: 步骤 8 中的图像 1,3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Receiver, Vibrator, Loudspeaker, Battery Transfer: 步骤 8 中的图像 2,3 Samsung Galaxy A7 (2018) Display Assembly Replacement, Receiver, Vibrator, Loudspeaker, Battery Transfer: 步骤 8 中的图像 3,3
    • Transfer to the New Screen frame:
    • Vibrator motor
    • Loudspeacker
    • Receiver
    • Use hot air and plastic tools to remove the battery.
  9. Samsung Galaxy A7 (2018) Display Assembly Replacement, That's all friends: 步骤 9 中的图像 1,1
    • That's all friends!
结论
19等其他人完成本指南。
ZFix
于12/09/13注册
191,882 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,516篇指南
2条评论
Hey!!!!!!. I’ve just recently fixed my A7 (2018) screen, and with this screen, you’ll have to remove the old one, and replace it. The adhesive what is on your old screen is very strong, So i advise to use isopropyl alcohol, and/or heat, also with suction, so that you can pry up the screen. Also, Do NOT bent the Flex Cable because it is very delicate, and it will tear easy. All in all, the repair was fun, for a repairman myself, and allowed me to use my talent!!. 10/10 Recommend
Marlion Russell - 回复
I want buy the screen for samsung a7 ?
Zouhair Guermah - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 72
过去 30 天: 362
总计 17,500
