跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1526 个问题 查看全部
Backup data with no screen, itunes doesnt detect
I have this iphone 6 plus phone that suddenly the screen stopped working, what happens is I see a blank screen with the backlight lit up, when I connect the phone through a lightening port to a computer or a charging adapter the backlight lights up.
Is there a way to make a backup/clone the data from this iphone knowing that the feature "data protection" is enabled and the passcode is known. can I verify the passcode to the device without having to use the screen? also There is no apple logo it's just a black screen with backlight, if the home button is pressed the backlight turns on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Definitely sounds like a you could use a new screen sort of scenario. To back up an iPhone you need to have one of the following scenarios.
Scenario 1 -
  • Charging functionality so it can stay on for long enough to complete a backup.
  • USB connectivity for transmitting data to a computer.
  • Working image so you can see what's occurring onscreen (backlight is a luxury, not a necessity).
  • Functional touch so you can unlock the screen, and initiate trust with the connected computer
OR
Scenario 2 -
  • Wireless charging functionality so the phone will stay on long enough to complete a backup.
  • Working image so you can see what's occurring onscreen (backlight is a luxury, not necessity).
  • Functional touch so you can unlock the screen.
  • Wi-Fi connectivity and a cloud based location to store the data
Right now it seems like you have at least 2 of the 4 things from the first scenario, but you do need the ability to see what's onscreen so you can unlock it. Even if touch is working, I recommend against doing too much guess work because I have seen far too many disabled iPhones which are permanently locked out after too many incorrect password attempts.
iPhone 6 Plus screens can be had relatively cheaply (in comparison to other iPhone replacement displays). But I would wager you will need a new one. I might also have a look at the iPhone Black Screen page, which could provide some other options to restore screen functionality without needing to purchase a new one.
iPhone 6 Plus Screen图片
产品
$59.99
这个答案有帮助吗?
得分 2
添加一条评论
Sounds like most likely you have a screen issue. Unfortunately, the screen has to come on and be functional with touch in order to connect to a computer and to back up the data.
这个答案有帮助吗?
得分 1
添加一条评论
So I managed to connect the phone to iTunes via 'recovery mode' I think,
I pressed the home button and power button for a few seconds then iTunes saw the phone and displayed the serial number,
it said there is an issue with the phone please "update" the software or "restore" to factory settings. I tried updating but every time it finishes the process it goes back to step one, asking me again to update then repeats the same after trying several times. I don't want to use the restore function as that will erase the data.
Also once iTunes saw the phone, the backlight became stronger but still no image on screen.
这个答案有帮助吗?
得分 0
2条评论:
Yes, definitely do not restore the phone if you need the data.. If you're not getting an image even in Recovery mode, it may actually be stuck in recovery mode at this point. This is almost certainly a hardware issue. So either a new screen, or something on the logic board.
完成的
@flannelist Thank you for your help, I'll look into that next then.
完成的
添加一条评论
添加你的答案
dozenchicken 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 57
