跳转到主内容
Released November 2018 as an edition to the iPad's Pro line. Model A1980.
63 个问题 查看全部
Do you think this repairable?
I didnt use enough heat to get the ambient sensor off and it separated.
I am getting the message that says Face ID cant activate, so I'm not sure if that's because of my installation is not right, or if its indeed because of the ambient sensor?
Can this even be repaired?
Attached is what the separation looks like from the sensor.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
This cable is needed for FaceID to function. It may be repairable with micro-soldering, but it looks like the traces were ripped from the cable, so it would be very difficult.
这个答案有帮助吗?
得分 1
1条评论:
Bummer! I know that the sensors are paired to system board so my only option would be to micro solder..
thank you! I needed that confirmation!
完成的
添加一条评论
If the pads have been ripped off then you probably have no chance. You might have to bite the bullet and go without face id. That or go down the expensive apple route.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Weger 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 87
