跳转到主内容
模具型号A1707。于2017年6月上市,这台MacBook Pro的特征为配有Kaby Lake处理器,可升级至2.9GHz、可动态超频至3.9GHz四核英特尔酷睿i7处理器。
329 个问题 查看全部
How do I clear the Battery service warning after replacing the battery
I replaced my battery with the iFixit kit (MacBook Pro 15" Retina (Late 2016-2017) Battery) , and went through a couple of cycles of charge/discharge to reset the battery controller. I still get the message in the battery control panel "Your battery capacity is significantly reduced..."
Following advice found elsewhere, I also did a shift-control-option-power up to clear the System Management Contnroller
I still get the message. Everything seems to work fine, but I'd like to fix this so I know if there really is a problem
MacBook Pro 15" Retina (Late 2016-2017) Battery图片
产品
$129.99
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Shutdown and carefully disconnect the battery, now press and hold the power button with nothing connected for a 15 sec's to fully drain the logic board. Reconnect the battery and power adapter let the system charge a good 5 hours. Restart your system and check the battery using CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
4条评论:
should I drain the battery first? and as it is a non-removeable battery, You are suggesting lifting the screwed down tab, as well as the removing the battery data cable?
完成的
@kevinosborn - Follow this guide 2017年带 Touch Bar 的15寸 MacBook Pro 电池更换 to Step 14.
No need to remove the battery just disconnect it! But before you do anything lets get a CoconutBattery snapshot so we aren't driving blind here!
完成的
it's added above. something is definitely hinky
完成的
@kevinosborn - You'll need to contact iFixit to get a replacement! Make sure you point to this question so they can see the CoconutBattery output and reference your sales receipt.
iFixit Customer Support
Sorry for the bad luck ;-{
If you would be so kind to score the answer and accept it that would be great! Thanks!
完成的
添加一条评论
添加你的答案
kevinosborn 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 20
总计 201
