跳转到主内容
Unable to get by BIOS Password
Bought a Dell M4400, understand it was a government computer. It appears to have BIOS passwords that prevents it from booting at all. It asks for a password when powered on. BIOS password removal tools do not work because the password prompt appears before the machine can boot from CD, etc. I've tried removing the battery for 5 minutes, and several other suggestions. I'm not very experienced with laptops and at a loss with one. I would appreciate any ideas. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Dell site says "type in 'dell' and see if that works. Another method Dell suggests is: https://www.dell.com/support/kbdoc/en-us...
完成的
添加一条评论
4个答案
最有帮助的答案
Dell laptops use a master password, but BEWARE: Anything with a Haswell*/Broadwell-present processor has an option in the BIOS to block the master password reset. If it's enabled, you have to replace the motherboard!
*Some Haswell business systems had it added retroactively. Ivy Bridge and older is permanently cracked wide open.
PLEASE READ: If you see this and ask about a newer computer, I am usually apprehensive to touch these questions. For the M4400, I'm answering it because anything from the Core 2 (Solo/Duo/Extreme) and the 1st-9th gen Intel Core i (AMD from the same period) is almost always locked due to negligence from a fleet decom. The odds of an old machine like this being stolen are very low, and most people acquire these from places like eBay, recyclers, and GovDeals/GovPlanet. If this were newer, I would not have answered this.
I'm not going to sugarcoat it: YES, I WILL TAKE THE "BIOS LOCKED" DISCOUNT IF I KNOW THE UNIT IS NOT STOLEN AND "RESET" THE PASSWORD ON THESE LAPTOPS TO REMOVE THE PASSWORD WHEN IT IS MISSED, EVEN ON THE NEWER "NO TOUCH" LAPTOPS I WILL NOT DO HERE.
The reason I will do this (especially unadvertised password issues) is I can either:
  • Remove it in 5 minutes and be done with it. Use my new laptop.
  • Start a return, spend ~1-2 hours getting there (or paying for an Uber)
    • Having to wait for it to arrive to the seller
    • get a refund
    • Look again
For locked units, if I'm getting it cheap over this issue, I either make sure it's decommissioning age (or there's a reason, such as company closure/downsizing) and get the unit at a price low enough as CYA. When I am alone and can get it done, I'm already working on the BIOS Admin/HDP passwords (as needed). Once I know the BIOS is unlocked, I will erase ALL of the hard drives/SSDs to be sure I am starting over clean*.
*In some cases with older models, the hard drives are high hour/have an issue. In those cases, I will replace the drive with an SSD if the laptop is nice enough to warrant it or it only takes SSDs. That said, I always account for it and assume the worst in my offer (especially on machines I know come with Seatrash/Seagate hard drives as the "common drive" of choice).
BEFORE ANYONE CALLS ME OUT: Let's say you were a mechanic (or know how to work on cars) and you saw someone sell a Lexus/BMW/Audi/Mercedes cheap due to a $50-100 problem the seller assumes is a thousand-dollar issue. Would you not take advantage of that and be able to drive around in an S550/S600 (even an E class) if you didn't know the cost of fixing the Airmatic suspension or other issue is cheap for someone who can do the work? It's the same in IT; we all laugh at it and know it's an idiot deterrent (seriously, we cover for this in the AUP). If someone is offloading an easily unlocked Precision with the i7 and high-end graphics (Radeon Pro/RTX workstation), I'm taking a chance.
However, the big issue (and this is why I offer accordingly) is Computrace. It's a non-issue on old machines, but you may need ownership info if it's newer.
I'm not going to provide links, but there's a site that can generate it if you know where to start (Note: the ST MUST MATCH, uppercase, and lowercase). On Dell, you need to press F2 or F12 (select BIOS setup if you use F12 to get into the OTBM), then enter the master password to unlock the system. Once Admin (under "Security options") says "Not set," you are done but do check the other passwords to be sure.
I ran into the issue where you need to clear it for good by removing it under Security on an NVS 160M 256MB (900p direct LED motherboard) E6400 I got from a charity since the seller did not check. I chose to crack it vs return it for the reasons mentioned above and to avoid the hassle (at some risk of not being able to return it, but I took it due to the specs).
ALSO, BEWARE OF COMPUTRACE! Contact Absolute SW, give them the ST of the laptop, and get it checked. If it is active, they need to disable that crap server side. You'll need a new drive and a new copy of Windows anyway, as the government destroys drives. Once Absolute Software severs the activation, the Computrace issue is resolved.
这个答案有帮助吗?
得分 3
添加一条评论
The default Dell Bios password is ( Dell ) for Dell bios master password please visit the Dell Bios master password page
once you have the right dell Bios master password in hands,
type the password and press enter, try also to apply the password from inside BIOS setup.
Also, Dell can issue a 'Master Password' to the owner of the equipment. Unfortunately, you aren't the original owner, and I doubt they transferred ownership via THE DELL TRANSFER OWNERSHIP PAGE. Hopefully you can get back with whoever sold it and organize this so you can get in.
Might be worth a call to Dell customer service anyway. You might have to prove that ownership was transferred somehow, or maybe you get someone who just gives you the password, if you're lucky.
Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
If you are talking about Bios password for dell showing Service tag ending in XXXXXXX-8FC8
it is now unlockable by using this page, https://www.biospro.com/dell-8fc8-bios.h...
If you are talking about Bios password for dell showing Service tag ending in XXXXXXX-E7A8
https://www.biospro.com/dell-e7a8-bios.h...
the master password worked in my computer store, so try it out and let us know.
这个答案有帮助吗?
得分 0
添加一条评论
No need to pay anyone..You can patch the 8FC8 bios and unlock it using a cheap bios programmer and this python tool. This app also has the old password generator as well.
https://github.com/chromebreakerdev/Dell...
这个答案有帮助吗?
得分 0
2条评论:
new 2.1 version out
完成的
new 2.5 version out, more tools added
完成的
添加一条评论
添加你的答案
S W 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 114
总计 3,121
