The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup. For the 2006 model year, several improvements were added to the F-150 lineup.
Kelly Powell I am confused "will shift manually " "shifter in the steering column won't shift " reads like it shifts but it does not shift. Okay so its an F-150 with a Manual or Automatic Transmission ( I bet it's automatic ;-) What happens when you move your shifter? Do you feel any resistance etc.?
Its an automatic I've had to get underneath the truck to shift it there's no resistance on the shifter the previous owner said the truck needed a shift pin that the old one broke on him twice
由 oldturkey03 完成的
由 Kelly Powell 完成的
I know this is old but I have the same problem. Can not out the shifter in any gear! This is an automatic!
由 Kim Carlton 完成的
