跳转到主内容
A1418/EMC3069/2017/3.0GHz四核心Intel Core i5、3.4GHz四核心Intel Core i5或3.6GHz四核心Intel Core i7处理器。于2017年6月8日发布。
Can an Additional SSD be installed?
Unit has blade ssd already installed. Is it possible to add an additional sata ssd?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Here's what you'll need:
iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit
Here's how to do it:
iMac Intel 21.5" Retina 4K Display (2017) Hard Drive Replacement
Upgrade the storage and improve boot time and read/write speed in your iMac Intel 21.5" Late 2012-2019 with this SSD upgrade kit.图片
产品
$82.99
这个答案有帮助吗?
得分 2
6条评论:
@bigmac98 & @mayer You'll also need the cushions and SATA cable as the blade SSD models won't have these.
iMac 21.5" (Late 2013-2017) SATA Cable
Hard Drive Rubber Frame v2
完成的
@danj If it doesn't already have a drive, will it also need the thermal sensor?
https://eshop.macsales.com/item/OWC/DIDI...
完成的
@mayer - The 2.5" dive systems don't need the thermal sensor as long as it supports the newer S.M.A.R.T. Services. All current drives are AOK!
完成的
Thanks for the help Mayer! Much appreciated.
完成的
@bigmac98 - Don't forget to vote and accept the answer if you're set!
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Will McCulloch 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 90
