跳转到主内容
加入维修社区 - 创建账户
logic board?... or something less expensive
My power cord to this PowerBook stopped charging my computer eons ago.... after research.i thought it might be the logic board that gave out but i just saw a link over to the right of here about a possible DC board that might be out? (for this model?)
anyways i want to get an enclosure for the hard drive to salvage what files are on there and just do away with the rest of the laptop.
what KIND OF ENCLOSURE would support a 44 pin ATA-5 drive? its from toshiba from my PowerBook G5 onyx ...
any feedback is greatly appreciated !
Thank You
'Berto
Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Go to www.ebay.com. Do a search for external hard drive enclosure & ide & 2.5
You'll find a couple of hundred
这个答案有帮助吗?
得分 1
3条评论:
Do not get one for SATA
完成的
Take a look at the old AC power input, the tips on these break a lot and sometimes lodge in the DC IN port. Let me know if this is the case and we'll work on that repair.
完成的
I think i see the different ones SATA ATA and IDE...
i bought a SATA one and found out that doesn't fit my 44-pin HD...
(I take it SATA is too advanced for my poor onyx toshiba 30 GB)
so i guess we go for ATA or IDE?
what do you think?
thank you guys very much for the quick answers...
its frustrating when you're so close to fixing a problem...and then its after hours and comp usas and other computer stores are CLOSED!@
完成的
添加一条评论
what do you think?
这个答案有帮助吗?
得分 0
2条评论:
Buy a IDE.
完成的
Check the date and time on your computer, I don't think it's set right
完成的
添加一条评论
添加你的答案
Onyx 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 12
过去 30 天: 16
总计 1,195
