跳转到主内容
索尼 PlayStation 5 DualSense 手柄的维修文档。 型号: CFI-ZCT1W FCC ID: AK8CFIZCT1
20 个问题 查看全部
L2 Button constant on even if not pushed
Hello,
i changed the two rings around the L3 button which caused stick drift , after getting all stuff together my L2 Button is like always enabled even if im not pushing it at all. How can i fix this ? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
最有帮助的答案
Try taking the controller apart again and then push the L2 button then release. If that doesn't work ,try replacing the trigger button. Hope this helps!
Diode
这个答案有帮助吗?
得分 1
3条评论:
tested some stuff and the L2 is even activated after i removed the left L1 and L2 unit from motherboard. So its something with the board i assume.
完成的
@Toni Montana Seems that way. All right. I don't know if I can help you in any other way. Sorry.
完成的
its a problem with the blue flat cable that connects the unit to the main board… try straightening the metals at the tip… worked for me
完成的
添加一条评论
Usually it happens when the board is loose. There's one screw that atach the board to the controller shell. Open the controller again and Make sure you've tightened it.
这个答案有帮助吗?
得分 0
添加一条评论
when I had close to the same problem, I had to replace the spring on the side of the trigger. Also, I completely disassembled and clean the adaptive trigger with contact cleaner bw-100, but the spring was my real problem.
这个答案有帮助吗?
得分 0
添加一条评论
The small white ribbon cable that connects the trigger rumble pack to the board if you look very closely at the blue tab end you'll notice the gold connection lines, these are very thin and can bend easily, get a new ribbon cable or try to straighten it and trial and error it until it works (keep the casing off and try a game like astrobot until it's satisfactory)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Toni Montana 将永远感激不已
浏览统计数据:
过去 24 小时: 17
过去 7 天: 113
过去 30 天: 428
总计 15,995
