跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
iPhone x Water Bootloop Cable Touch Screen
Hi a friend of mine dropped his Iphone X in the water. After turning it off and keeping it in rice for a week he went to turn it back on but keeps going into bootloop. The logo lights up, a small line appears on the screen and then goes out. So I went to open it and in the end I found that disconnecting the touch screen cable the phone starts up normally. Now my question is: can anything be done? Can the contacts be cleaned in any way? Could I solve the problem if I completely change the display?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi
Rice does not solve the problems caused by corrosion due to water coming into contact with electronics. Rice is for dinner, not repair
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove/disconnect the battery as soon as possible from the phone to minimize any further damage.
Given that it seems to work by only having to disconnect the digitizer flex cable hopefully all it needs is a screen replacement but time will tell.
Here is the ifixit iPhone X 屏幕面板更换 guide that will help with this
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Jeremy Meini 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 66
