跳转到主内容
Repair guides and support information for RCA-brand tablets.
1271 个问题 查看全部
Where do I find an LCD for RCA RCT6513w87dk (RCA 10 Viking pro)
I have searched far and wide and cannot find an LCD for my RCA RCT6513w87dk. So I have resorted to asking here if anyone knows where I would be able to acquire one for the tablet. I also measured the screen to be around 11.6 inches if that helps any more.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Justin Orange, do you have it apart already? Any markings on the back of the LCD? I hate RCA for using LCD's that are so difficult to find. I can find some for the RCT6303 but am not sure about compatibility.
完成的
Second @oldturkey03's comment; I had a laptop that I simply could not find an LCD for until I opened it up and found the manufacturer and their part number for the screen itself. After I had that I was able to locate several other devices that used that same part and ended up finding one that was used on a different laptop.
完成的
@oldturkey03 I found on the back XianChuang M115WSBN40-03A. I also attached an image of the inside.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi Justin,
I spent a bit of time poking around on the internet, and here's what I found.
First of all, it appears that model RCT6513w87DK is called a Galileo Pro rather than a Viking Pro; that may have contributed to your difficulty in finding a replacement screen.
I was unable to locate any screens using the manufacturing information (XianChuang M115WSBN40-03A), unfortunately. I did find that it appears the first three numeric digits of the model number are supposed to indicate the screen size; in other words, the "115" part of M115WSBN40 stands for 11.5 inches.
However, I did come up with a couple of them on eBay that should work. The search worked much better leaving off the last two letters DK from the model number. You'll have to take a look at them for yourself and decide if they're the right one.
RCA Galileo Pro RCT6513W87 11.5" Genuine Tablet LCD Touch Screen w/Battery
11.6'' LCD Display Screen for RCA 11 Galileo Pro RCT6513W87 Panel free ship #JIA
The first one is a complete display assembly with digitizer and battery (used), while the second is just the LCD itself; you were specifically asking to find an LCD, so I don't know if you need the digitizer as well or not. If that was the case, the digitizer is also available on eBay; it looks like it's running about $15 USD new like this one.
For RCA Galileo Pro 11.5'' RCT6513W87DK Touch Digitizer Screen Replacement
Hope that helps get you going again!
这个答案有帮助吗?
得分 1
1条评论:
I ordered the LCD and digitizer because they looked like they would work. It's probably going to take 2 weeks to ship so I guess we will see if it works.
完成的
添加一条评论
添加你的答案
Justin Orange 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 107
