跳转到主内容
Nintendo Game Boy Advance, released in 2001. Repair requires only common tools and no heat.
54 个问题 查看全部
Game Boy Advance starting up in black and white
I Bought a modded GBA, and it was working fine, but the screen was miss placed, so I opened it and put the screen on the right position. When I tested with the gba still open it was working fine, but after closing it, the screen now has no colors, everything else works just fine, it's only the screen that is now on black and white. I believe it's a IPS V3 screen. I tried re-opening, and checking for burned components, broken cables, but nothing.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Try reopening it if there are any ribbon cables make sure they’re in all the way
这个答案有帮助吗?
得分 0
添加一条评论
I had the same issue recently and learned how to fix it by luck. Hold your finger over the touch sensor that changes brightness and then hold either start or select, it may take a few seconds but the color will turn back on. It can also be done again to make it black and white again. Sometimes I have to try it a couple times too, but it always works for me. Hope this helps😸
这个答案有帮助吗?
得分 0
1条评论:
I have the same problem on my Gameboy color and I tried doing this but it didn’t change.
完成的
添加一条评论
添加你的答案
Marmita Fria 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 23
过去 30 天: 75
总计 1,655
