跳转到主内容
加入维修社区 - 创建账户
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Joy-cons don't stay on rails
When playing in handheld mode, both of my joy-cons don't say on the switch rails. They slide out even when I don't press the unlock button to do so. How can I fix this and can I do it without the need to open up my joy cons?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I've had to do this repair myself, so I can tell you pretty definitively that you need to replace the part called a buckle lock on each of the joy-cons. The ones that come with the unit are plastic and since they contact against the metal rails the joy-cons slide into, they eventually wear out and won't hold the joy-cons in place any more.
The good news is you can buy replacements made of metal that will never wear out again.
The bad news is no, you can't do it without opening the joy-cons. The replacement isn't particularly difficult, but you do have to pay attention to which buckle goes in which side, as the two are different and if you put them in the wrong side they don't work. iFixit already has a replacement guide all ready to go for you.
Joy-Con Buckle Lock Replacement - iFixit Repair Guide
Here's a link where you can buy metal replacements for $4.99 USD (at the time of this writing).
Nintendo Switch Joy-Con Replacement Metal Buckle Locks - iFixit Store
Two metal replacement latches for a pair of Joy-Con Controllers.图片
产品
$5.99
这个答案有帮助吗?
得分 3
3条评论:
Cries my self to sleep
Thank you for the answer
完成的
JERRY WHEELER YOU ARE THE MAN!!!! I was terrified that the buckle lock wasn't my problem, but turns out I was using the wrong one! You literally saved my life.
完成的
@hannahfort LOL, you should be aware that the reason I know that fact is that I put them in wrong and found out they didn't work. It wasn't till I took them back out again I realized they are different for each side. I didn't feel it necessary to let people know I'd made a stupid mistake in this post, but on others I've told folks "don't be me".
完成的
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 34
过去 30 天: 148
总计 6,238
