简介
使用本指南,用金属扣锁或新的塑料扣锁来更换任天堂 Switch 的 Joy-Con 手柄中的扣锁。
左右两侧的 Joy-Con 手柄之间存在一些细微差别,但这些差别都不会影响更换操作的步骤。以下这些步骤适用于左右两个Joy-Con 手柄。
你所需要的
将你的电子垃圾送到经 R2 认证或电子管家认证的回收商 处。
维修过程没有按计划进行?请查看我们的 答疑社区 以获取故障排除方面的帮助。
158等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
40指南评论
I tried to do this carefully, but I ended up removing the side rail ribbon cables and I had to disassemble the whole thing just to try to get to the inside of these babies. However it seems I messed up, and now I could use some help here. I don't want to lose my left Joy-Con.
Francisco Q. - 回复 分享
I bought this kit of replacement metal buckles, and they work beautifully: https://www.amazon.com/gp/product/B07BDH...
This kit comes with four buckles, two for the left Joy Con, and two for the right. If you happen to have two sets (or plan to get a second set) of Joy Cons, a whopping $9.00 will set you up right.
I did have a bit of trouble replacing the metal cover that holds the buckle in place, but that was my own stupidity as I was trying to do this repair with insufficient light. Once I shed some light on the subject and I could see what I was doing, everything went back together smooth as silk. I replaced the buckles on both of my Joy Cons, and they’re both rock solid now.
itpurchasing - 回复 分享
