跳转到主内容
The sander pad only vibrating not spinning.
Replaced brake ring no change
The motor is spinning very fast, but the sanding pad is not spinning.
The sander pad can easily be spinned manually.
I dont know where is the connection between the motor and the sanding pad
Parts spinning: #30 inner bearing ring, #33 washer, #34 screw see attached drawings
Parts NOT spinning: , #29 outer Bearing Box , #32 Bearing Box Cover, #35 sander pad and #36 bolt,when assembled these are "sanding assembly" this assembly can be spinned manually but is not spinned by the motor see attached drawings
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@speculant Did you get this sorted Hans- I have the same issue
完成的
after brakering replacement i could use it again, first let it go up to speed the put on the wood.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @speculant
Check if the motor brushes are OK and not worn out. These connect the power to the motor causing it to turn. Also ensure that the motor spindle turns freely when manually operated and is not jammed.
Here's the service manual for the sander, that may help.
Here's a link to a parts supplier that may also help. For example if the brushes need to be replaced see Item #8 in the parts list to find the Makita part # i.e. CARBON BRUSH CB-64 BO3710/11 .
Given that it is a variable speed sander, it may also be that the controller not supplying enough power to the motor to turn (part #37 CONTROLLER 240V BO5041)
Search online using the information from the linked parts supplier list, to find suppliers that suit you best.
Hopefully this is of some help.
这个答案有帮助吗?
得分 1
19条评论:
Hi @speculant
Is the fan turning? If not check bracket part #22
完成的
Yes the fan is spinning but the sander pad is not spinning
完成的
@speculant
I don't think that the bearing box or the brake ring should turn as they have notches which should lock into the skirt - see the image on p.5 of 9 in the manual for how the brake ring is locked in with the protrusions.
完成的
since the sanding pad is connected to the bearing box i think it should be spinning.
The brake ring is static to center the spindle I think.
完成的
@speculant
Can you manually spin the inside ring of the bearing box? It may be that the bearings are seized.
完成的
显示更多的14条评论
添加一条评论
添加你的答案
Hans 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 66
总计 2,130
