The sander pad only vibrating not spinning.
Replaced brake ring no change
The motor is spinning very fast, but the sanding pad is not spinning.
The sander pad can easily be spinned manually.
I dont know where is the connection between the motor and the sanding pad
Parts spinning: #30 inner bearing ring, #33 washer, #34 screw see attached drawings
Parts NOT spinning: , #29 outer Bearing Box , #32 Bearing Box Cover, #35 sander pad and #36 bolt,when assembled these are "sanding assembly" this assembly can be spinned manually but is not spinned by the motor see attached drawings
2条评论
@speculant Did you get this sorted Hans- I have the same issue
由 Jeff Crawford 完成的
after brakering replacement i could use it again, first let it go up to speed the put on the wood.
由 Hans 完成的
