跳转到主内容
The Manscaped Lawnmower 3.0 is a waterproof, cordless, electric trimmer for body hair.
3 个问题 查看全部
Manscaped Lawnmower 3.0 not charging
Hi,
my Manscaped Lawn Mower 3.0 shaver has stopped charging is there any way to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Our manscape will not charge, please chased in February, Is there a warranty?
完成的
添加一条评论
3个答案
最有帮助的答案
Hi,
Here's a video that may help.
这个答案有帮助吗?
得分 2
添加一条评论
Hi @ksewellato45896
It might depend on your location. In the USA and Aust/NZ it is only 90 days but it may be different elsewhere
这个答案有帮助吗?
得分 1
1条评论:
Gone trough all the steps carefully to be sure it was done correctly and all I’m getting (even by-passing the base) is a very fast flashing. Initially when it started acting up, it would go from normal steady flashing to this fast flashing but now it’s all I get. I left it overnight with no new results, am I missing something?
完成的
添加一条评论
Check the cable, charger and outlet. You can email manscape and they will give u free a new cable and charger. To check the outlet simply plug your phone in and look if it's charging. Once those are out of the way there's 2 possibilities, either the battery is dead or the charging pins are dirty. If the battery is dead, the trimmer will have a much shorter battery life after the previous charge.
Now that all of those are out of the way it's time to clean the pins. Disassemble the trimmer per this video https://youtu.be/wYvKmZJ7Vng. Take out the pins and soak in vinegar for 30 seconds. Do the same for the pin receptors ensuring only the receptor, not the board, is in vinegar. Dry them and use a thin pointy object to scrape off any debris that is on the pins or receptor. Finally reassemble.
I hope this helps someone.
这个答案有帮助吗?
得分 0
1条评论:
Checked mine by unscrewing the bottom plate of the charger (screws are under rubber feet)
Corrosion ate away one of the leads connecting the power cable to the adapter in the cradle. Whisker like lead had no chance for long term life.
Corrosion ate away one of the leads connecting The wall adaptor to the cradle adaptor.
完成的
添加一条评论
添加你的答案
Jack S 将永远感激不已
浏览统计数据:
过去 24 小时: 36
过去 7 天: 244
过去 30 天: 904
总计 51,871
