跳转到主内容
加入维修社区 - 创建账户
苹果的iPod Touch第六代于2015年7月发布。
Why isn't the power button working?
So recently I took apart my iPod Touch to replace the battery, which I did successfully and it works, but when I was replacing it and took out the motherboard because I thought that I had to. Now the connector is loose to the board, and when I manage to get it to stay in it is still loose. Does anyone know how to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi
My first (major)repair was one of these and I had this exact issue because it’s really annoying to blindly get connectors connected from behind
I find I you get the cable and remove the little bit of silver/grey tape fabrics stuff and extend the cable until it’s straight
Before you do that you need to get the logic/motherboard out and you can kind of flip it and connect it fairly easily
It’s a bit bad to explain but if you need any help just ask me in the comments and I can help you at every step of the way:-)
Hopefully this helps
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sean Murphy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 250
