跳转到主内容
加入维修社区 - 创建账户
适用于 Logitech VX Nano 的维修指南、拆解和故障排除信息。这是一款专为笔记本电脑设计的无线激光鼠标,发布于 2007 年 7 月,型号为 M-RCJ134 或 910-000253。
Mouse won't power on
My Logitech VX Nano Wireless Mouse won't power on. I replaced the batteries. And no, the receiver is not in the storage slot. It is not a connection issue; it was working fine, then stopped. Thought it was the batteries, but new ones did not cure the problem. I can't find any troubleshooting for this problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
can u take a pic of the board plz
由完成的 分享
Hi @kamsh
Had you tried with another computer?
Is the usb receiver detected on the computer? you can check on device manager.
when you pull out the new battery and insert again, do you see any LED light showing up on top of the mouse?
由完成的 分享
I have the exact same problem. The USB receiver is detected but none of the LED lights are lighting up when batteries are inserted.
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
if its not getting any power light then its a power issue.
did anything happen suddenly before the old batteries die? any possible liquid damage?
might sound silly and i HATE to ask but are the batteries in the right polarity?
and youve obviously tried confirmed fresh batteries?
are they rechargeables ?
have you checked to make sure the contacts are extended enough for the negative to make a solid contact with the batteries?
any corrosion?
if youve checked all that you may need to open the mouse up and take some voltage readings and make sure the board is getting power. if it is then you have a bigger issue and will need further trouble shooting.
这个答案有帮助吗?
得分 1
2条评论:
When you insert the nano receiver in is't slot next to battery compartment, the receiver push a button inside the mouse to disconnect power to conserve battery. This function is in replace of a power switch that not available in VX Nano.
由完成的 分享
The push button inside the mouse need to be cleaned or replaced.
由完成的 分享
添加一条评论
添加你的答案
kamshopping 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 966
