跳转到主内容
加入维修社区 - 创建账户
一款由联想制造的搭载 ChromeOS 的笔记本电脑。它拥有 11.6 英寸显示屏、英特尔赛扬处理器、4GB 内存和 32GB 内部存储空间(eMMC)。
Won't power on
I do chromebook repairs for a school district and I have come across a couple hundred 100es that have a charge light, are fully charged (left on charger for 1 day or more), but don't seem to turn on. I've verified that the battery and screen/topcase are working by testing them on other chromebooks. I've also plugged in an external display and the cbs are not sending any display signal. Seems to be any issue with the motherboard perhaps?
I've tried these troubleshooting steps (aside from verifying the physical components as noted above)
-forcing a powerwash
-draining flea power
-unplugging all connections from motherboard and reseating them
-toggling "shipping mode" on the batteries
Sorta at a loss. Anyone else experience this issue or have a fix ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I would check the battery’s with a multi-metre to make sure they are charging
If they are t you will have hook them up to a bench power supply and charge them at a low power going into them as we won’t want to damage them do we:-)
完成的
添加一条评论
2个答案
The Lenovo 100e Chromebooks have a problem with ribbon cable flaps not staying in place. Open the bottom of the unit and check the flaps on the ribbon cables of the power board. one will probably be up or not down tight. we place a small piece of electrical tape on them to hold the down.
这个答案有帮助吗?
得分 0
添加一条评论
please help me fix it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Caitlin Wolf 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 36
总计 1,054
