Toshiba tv won't power up all the way
Toshiba 55l7200u tv has flashing green light with Toshiba across center of screen. won't power up. have done all the suggested solutions of unplugging and holding down the power button to no avail. That has worked in the past but it doesn't now. its been an ongoing issue for awhile. Any more suggestions besides replacing it. thanks Chaz
6条评论
@chazby are you saying it hangs up on the Toshiba splash screen and never goes past that? Does this model have chromecast built in?
由 oldturkey03 完成的
no chrome cast
由 Chazby 完成的
just hangs up on Toshiba and sometimes screen goes black then Toshiba appears again
由 Chazby 完成的
Hi @chazby
Not sure if this will work or even if it will brick the TV but maybe try updating the firmware via USB.
I realize that your model is not listed in the update procedure list of models but since Toshiba is not known for releasing service guides or schematics for their TVs it might be worth a shot.
由 jayeff 完成的
Thanks for that info. I will give that a try.
由 Chazby 完成的
显示更多的1条评论
