跳转到主内容
Apple 2020年的顶级智能手机。iPhone12 Pro Max于10月13日发布并于11月13日发布,配备6.7英寸OLED显示屏,带LiDAR的三重后置摄像头系统和5G连接。iPhone 11的后继产品。 专业版
114 个问题 查看全部
Phome stuck on Apple logo
Hi, hope you're well. I'm contacting you regarding my phone that I recently broke. A weight fell on it causing it to crack the screen, half of the displa still worked with touch but there was a temperature message on it, so I contacted apple and they told me to update it via a mac book which I done, but now it is stuck on the apple logo. I've got a lot of data in the phone which is not backed up, so I was wondering whether u know any fix for this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You have a couple of options
1.       Send it to a reputable repairer to retrieve your data.
2.       Attempt the repair yourself by ruling out a parts issue. The easiest way to do this is to transfer the logic board into a known good housing. This will completely rule out a parts issue. Unfortunately this is not usually practical for most individuals so you could try the following.
·         Replace the screen as if you updated the phone you will need to enter passcodes so you will need the whole screen to be operatable.
·         Start disconnecting one flex at a time and try to boot starting with the top flex assembly. If it doesn’t boot after this you will need to
·         Replace the battery.
·         Replace the lightning connector assembly.
If the phone still doesn’t boot you will have a board level problem that will need someone experienced to find the faulty component.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tayyab Ali 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 66
