Backlight spots at bottom of screen
I swapped the display and logic board (the old screen had the same problem but the display was broken, and the keyboard in my other MBP was broken) and this wasnt there on the old chassis
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 21
总计 184
5条评论
@danby that is stage lighting and is caused by a failure of the backlights. Check the display connector voltages and check the filter capacitors around that connector. It is possible that you a. have a bacd connector b. Bad capacitor or a bad backlight/display. Let us know what you find out after you have checked
由 oldturkey03 完成的
Either I'm confused or you are. You say "the old screen had the same problem" and then you contradict yourself by saying "this wasnt there on the old chassis".
You're looking at either a bad video connector, a bad video cable, a bad display (I've seen many cheap ones from China looking like that), or (possible but low on the likelihood scale) a bad logic board.
由 Steve 完成的
My old 2012 Macbook pro had the same issue!
由 Ben Capehart 完成的
@beanman56 did you fix it with a new display or did you find the bad caps on the board?
由 oldturkey03 完成的
@oldturkey03 - neither it broke (keyboard and motherboard)before I found out the issue
由 Ben Capehart 完成的
